Perform this procedure to configure CP Limit functionality to protect the switch from becoming congested by excess data flow through Extreme Integrated Application Hosting (IAH) ports.
- Select the IAH port you want to configure.
- Select the CP Limit tab.
- Select AutoRecoverPort.
- Select Apply.
CP Limit Field Descriptions
Use data in the following table to use the CP Limit tab.
Name |
Description |
AutoRecoverPort |
Enables or disables auto recovery of the Extreme Integrated Application Hosting port from action taken by CP Limit or the link flap features. The default is disabled. |
